Helo,
i need to get the Setup Type selected in instalation process in put this one in .ini file. This is like: Tipical, Minimal, Custom...
Some features as the database directory can be refer by [DATABASEDIR] for exemple.
Thx 4 all.
best regards,
Rick
Getting Selected Setup Type
ricardoaleite
, Aug 26 2005 11:45
Posted 26 August 2005 - 22:19
There's a proeprty assigned to the readio button group. You can get the value of this property by enclosing it in square brackets. The problem is that private properties (i.e. their name includes lower case characters) are not handed over to the execute sequence. So you would have to change your setup type dialog to make it use a peroperty name in upper case, like SETUPTYPE. Of course you also need to adjust all other references to this property name.
