Hi all,
my customer wants a setup (until tomorrow) where the program is not installed into "c:\program files" but into the directory "C:\HisCompany\Test".
First question: I have already a msi-file and Orca (no InstallShield or so). What do I have to declare in which table to force the installation into this directory?
Second question: the only thing that could be changed would be the drive-letter, but the path has always to be the same. If it is not possible to make the drive-letter flexible, I will provide two setups for him: one for drive C: and one for drive D:. I know that thats bad style, but I have to have the setup until tomorrow.
Please help anybody. Thanks!
andre
Fixed install-directory
andre
, Dec 16 2004 09:42
Posted 16 December 2004 - 13:34
For this you need to use the directory table to modify the installation directory as required. You can also use a SetProperty (before completion of costing) or a set directory (after costing) to change the desired directory.
If you have a dialog to set the destination directory then you can attach an event to do this for you. This way you would not need to hardcode either C: or D: or any other drive letter
Kapil
Kapil
