Hi all,
The installation i am currently working on uses MTS technologies, and has to install a number of private queues on the client machine under control panelAdministrative Tools/Computer Management/MessageQueueing
Does anyone know how to do this ? Or even if it is possible to do this?
thanks for any suggestions
Berni
Creating a Private Queue
bernadettefearon
, Jun 27 2002 15:54
Posted 03 July 2002 - 10:19
Definitely possible, I set up a number of queues for the main application I work on. The following is an extract from a support dll I use. The queue created is a public queue, but you'll get the idea from this.
It's also possible to create it through a VBScript/Installscript, but I can't remember the objects I call through VBScript. VBScript also had problems setting queue security, because the security requires calls to Windows API functions that aren't available to VBScript.
| Code Sample |
STDMETHODIMP CMSMQUtility::CreateQueue(/*[in]*/ BSTR istrPathName, /*[in]*/ BSTR istrLabel, /*[in]*/ VARIANT_BOOL iblnTransactional, /*[in]*/ BSTR istrTypeID, /*[out, retval]*/ BSTR* ostrFormatName) { try { // Delete the queue first in case it exists. if ( SUCCEEDED(DeleteQueue(istrPathName)) ) { // Set the queue details. IMSMQQueueInfoPtr pInfo(__uuidof(MSMQQueueInfo)); pInfo->PathName = istrPathName; pInfo->Label = istrLabel; if ( istrTypeID != NULL && ::wcscmp(istrTypeID, L"") != 0 ) pInfo->ServiceTypeGuid = istrTypeID; // Create the queue. CComVariant varTransactional = iblnTransactional ? true : false; CComVariant varWorldReadable = true; pInfo->Create(&varTransactional, &varWorldReadable); // Return the format name. *ostrFormatName = ::SysAllocString(pInfo->FormatName); } } catch ( ... ) { } return S_OK; } |
