focus problems in win2000
Posted 03 May 2001 - 11:38
It is very urgent , help me out.
Thanks in advance.
Posted 20 May 2001 - 20:58
My OS is windows 2000.
If you found a solution to this pb please do let me know too...coz I am stuck
this is urgent!
Posted 22 May 2001 - 07:17
You could use for example ShowWindow.
ShowWindow(HWND hWnd, int nCmdShow)
Pass the MSI window handle to hWnd and you could use one of these for nCmdShow:
SW_SHOW
SW_MAXIMIZE
SW_RESTORE
I also looked up the values for the constants in case you need them.
SW_SHOW = 5
SW_MAXIMIZE = 3
SW_RESTORE = 9
If you still have problems post a reply.
Posted 22 May 2001 - 07:26
Posted 23 May 2001 - 02:03
What is happening is that when i build the
project and run setup.exe it shows a Billboard (green
color background on Desktop) followed by
WelcomeInstall dialog box. For one second the
billboard occupies the whole desktop covering taskbar
etc (as expected) but the next moment the taskbar
appears at bottom.
Also simultaneously, The WelcomeInstall dialog box
appears TWICE first time with focus and next time
without it (focus)...and finally focus goes to taskbar
instead of Dialog box. This happens with the
successive boxes too.
So there are two issues involved:
1. Focus pb: Focus goes to taskbar instead of
remaining on dialog boxes.
2. Welcome dialog box appearing twice.
Note:
1. The Billboard is NOT present in Billboard table
2. The BBControl table has no entry as well.
I tried to put values in these tables but was not sure
what values should be put.
3. There is a topic called 'BillBoard Properties' in
Installshield help which talks about several imp ones
but i could not find any table where i could give
these properties to my billboard.
Pl help...
will try your suggestion too.
Posted 23 May 2001 - 03:44
1. COntrol goes to this line of code but background color does not change
2. Also, about ShowWindow() in installscript, we want the focus on InstallWelcome dialog too (which is first dialog box) so what should i tie the custom control (which calls this function) with.
Pl help
i am stuck..
Pl note that if i remove billboard (which i have used only for its Background property) the focus pb is gone)..
there must be an easy way of doing this...
Posted 23 May 2001 - 06:39
I don't use billboards. To change the color of the background and the the background image I use code like this rather than billboards:
Enable( FULLWINDOWMODE );
SetColor(BACKGROUND,RGB (2, 40, 80));
PlaceBitmap(szBmpDir,0,0,0, UPPER_LEFT);
You can also add this to the end if you like:
Enable(BACKGROUND);
This still doesn't fix the focus problem. Probably a bug in the MSI engine??????
I use an install wizard created with c++. I only use MSI for file copying so I don't have to worry if the MSI dialogs have focus.
Posted 23 May 2001 - 16:55
Btw, where do you write the script, i mean, you create a CustomAction and call all those functions but to which button (on which dialog box) will you tie the custom action..because we want the background right from beginning (on/before InstallWelcome dialog box appears).
ALso, on which verion of Installshield are you seeing this problem?
I am seeing couple of postings related to this topic.
I only wish that some Administrator would read our posting and verify if this is a bug in InstallShield (for InstallShield Professional Windows Installer Edition 2.0). That way we could close the topic and not waste more time and effort trying to find a work around.
