Is there a way for a custom action in a standard DLL to know that setup is running in silent mode in order to remove any user interraction ?
Silent Mode
matrot
, Oct 18 2002 15:02
Posted 18 October 2002 - 15:41
if you use the MSISetInsternalUI(INSTALLUILEVEL_NOCHANGE,0) then the return value will show the original UI Level requested.
the actual UI level can be effected by the LIMITUI property. i haven't done it but you are supposed to be able to check the UILevel property after calling the MSISetInternalUI to take this into account...
Posted 23 October 2002 - 09:18
Is this technique supposed to work in a deffered custom action in the Execute Sequence ?
In my last test, MsiSetInternalUI(INSTALLUILEVEL_NOCHANGE,0) returns INSTALLUILEVEL_DEFAULT when the setup is run with the /s /v"/qn" command line switches.
Posted 23 October 2002 - 09:25
If you create your interactions with MsiProcessMessage rather than MessageBox or CreateDialog then Msi will look after the need to display or not. It will also log the intereaction for you.
In general there should be as little user interaction as possible in the execute sequence. I appreciate this is sometimes impossible to avoid.
Ian Blake
(Currently Unemployed)
Posted 23 October 2002 - 10:26
If I've to launch a process that could run in quiet mode from the command line. But if I can't rely on MsiSetInternalUI return value it will be difficult ?
