I'm using InstallShield Pro 6.31 to install an application that has a component that has to be installed as an add-in in Excel. I use the code at the end the message. When I run this on a German Windows 2000 SP2 with German excel2000 and I get to the RegisterXLL line I get an error "Ausnahmefehler des Servers" ("Exception failiure of server" or something, I don't speak German).
The exact same code run just fine on english windows 2000 SP2 with english excel 2000. And if I translate the code to VB it runs fine on any language.
I think it's most likely something in InstallShield since it works in VB. Does anyone have any ideas whats going on here? I've searched MSDN and the installshield knowledgebase without finding anything.
/Max
Installshield script code snippet:
set oExcel = CreateObject("Excel.Application");
if (!IsObject(oExcel)) then
Err.Raise(1000, "Error adding Excel Link");
endif;
oExcel.Workbooks.Add();
set oAddIn = oExcel.Addins.Add(sLinkPath ^ "frangoxl.xll");
oExcel.RegisterXLL(oAddIn.FullName);
oExcel.Addins("FrangoLink").Installed = TRUE;
set oAddIn = NULL;
oExcel.Quit();
