Hi
I have msi package created by MTS. Its for Application proxy purpose. (DCOM)
I know I can use either
VB script for install/remove msi package
MIB426
, Nov 26 2003 03:14
Posted 26 November 2003 - 03:14
'Run the export package to register the DCOM component Dim WshShell Set WshShell = CreateObject("Wscript.Shell") WshShell.Run("C:\CINET.MSI") set WshShell = Nothing |
or
Dim msi Set msi = CreateObject("WindowsInstaller.Installer") ' set the UI level to basic msi.UILevel = 2 ' launch the installer msi.InstallProduct "C:\CINET.MSI", "" ' clean up Set msi = Nothing |
to install my package. I like 2nd method so It doesnt show up dialog.
Does anyone know how to remove my package in VBScript?
Thank You
Posted 26 November 2003 - 04:04
Couldn't you just run shellexecute on msiexec.exe? Something like:
msiexec.exe /x YOURPRODUCTCODE
Posted 26 November 2003 - 04:14
Hi
I never know u can use it..
so I rewrite my code as below
Dim WshShell Set WshShell = Wscript.CreateObject("Wscript.Shell") WshShell.Run("msiexec.exe /x CINET") Set WshShell = Nothing |
Now I got error...do u know how to get YOURPRODUCTCODE?
thanks
Posted 26 November 2003 - 04:18
Hi
I found out I can just point to msi file. My problem is sloved.
Thank you for the tip
