Hi all,
Here's what I'm doing to pass a Public Property value into the Deferred Sequence....
Create a Set Directory Custom Action...
Property: NEEDEDINFO (the name of another Custom Action that accesses the information)
Property Value: SOMEINFO (property holding the information that needs to be passed)
I know I can then create a custom action named NEEDEDINFO and access CustomActionData, for example, by vbscript using Session.Property("CustomActionData").
What I was actually hoping to do is to create the NEEDEDINFO Custom Action to fire an .exe. I was then thinking I would be able to pass [CustomActionData] as one of the parameters to the .exe, but that doesn't appear to work. Is that truly the case that I can't do that? Or, am I doing something wrong.
Any information is appreciated!
Thanks!
Passing Custom Action Data as a Parameter
Superfreak3
, Sep 20 2010 21:29
Posted 20 September 2010 - 21:54
It appears that instead of passing [CustomActionData] to the .exe, if I pass [NEEDEDINFO] as the command line parameter it works.
Good thing I only really have to pass one thing to Custom Action Data right now so there's no parsing needed at this time.
Posted 22 September 2010 - 14:29
That's correct, because the command line is written to the install script in immediate mode, and then gets called from the scripot in deferred mode.
