I am trying to create a new customized dialog box which will be exactly similar to sd status dialog box. Only extra item on it will be a list box. I want to update the contents of list box with file names as the files are moved to system. Can any one help me out.
Jai Krishnani
Customizing Set Status Window dialog
jaikrishnani
, Aug 09 2006 08:50
Posted 11 August 2006 - 09:47
i am also trying to create a customized dialog which will show steps on right and status on left related to that step.
I found a link which is helpful:
http://www.installsi...en/msi/tips.htm
Programming Billboards and Progress Bars
It is for basic msi but you can implement it for installscript msi also
Hope it helps u
i m still confused though in using it
Hope it helps u
