How do I set the TCP/IP property to get an IP Address from a DHCP server with InstallShield script? If if a machine has a static IP, I need to change it to get an IP from a DHCP server.
DHCP
akpoluru
, Nov 21 2002 16:31
Posted 21 November 2002 - 18:12
WHy do you want to do that? I personally use a static IP address for a very specific reason. If an installer came along and changed that, I would be extremely upset. Maybe you should look at what you're trying to do and see if there is another way of accomplishing it.
Posted 21 November 2002 - 18:45
Xitch13,
I am writing an installer for another app. and for this app. to run DHCP has to enabled. The user who is installing this app is aware of the change and he/she has specific instructions on how to do this manually. I want to automate this and was looking for help.
Posted 21 November 2002 - 19:40
you could try setting the following registry for the specific network card:
Key=HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\XXXX\Parameters\Tcpip
Name=EnableDHCP Value=1
the difficulty comes in when you have to determine a variety of nic cards on different machines...
