But IS cannot change the time displayed to the ones that are left. So now nearly half the install process has no billboards.
Is there a way to change IS so it displays fewer billboards for longer?
Posted 06 December 2001 - 13:15
Posted 06 December 2001 - 15:18
Also, the files are numbered. Are you just deleting arbitrary files and leaving the out of sequenced files? You may want to have the files under a different name and do the copy to the correctly sequenced names before enabling billboards.
Be sure to post what works.
(Edited by lasenbby at 2:19 pm on Dec. 6, 2001)
Posted 06 December 2001 - 15:27
begin
//Check for which build
DetectBuildType ();
//Delete the Billboards which do not apply
if (StrCompare(gszBuildType,"Public") = 0) then
DeleteFile(SUPPORTDIR ^"Bbrd4.bmp");
RenameFile(SUPPORTDIR ^"Bbrd5.bmp", SUPPORTDIR ^"Bbrd4.bmp");
DeleteFile(SUPPORTDIR ^"Bbrd6.bmp");
RenameFile(SUPPORTDIR ^"Bbrd8.bmp", SUPPORTDIR ^"Bbrd6.bmp");
DeleteFile(SUPPORTDIR ^"Bbrd7.bmp");
DeleteFile(SUPPORTDIR ^"Bbrd9.bmp");
endif;
end;
//THen do the secondary Installation of database.
function BOOL DoSecondaryInstallation()
NUMBER fError, nvDx, nvDy ;
begin
Enable(BACKGROUND);
//SizeWindow(BACKGROUND, 808, 606);
SetColor (BACKGROUND, RGB (0, 153, 216) );
SetDisplayEffect (EFF_FADE);
Enable(FULLWINDOWMODE);
PlaceWindow (BILLBOARD, 0, 0, CENTERED);
//BB's are 600(w) x 800 (h)
PlaceWindow (STATUSDLG, 30, 30, LOWER_RIGHT);
fError = FALSE; // default of successful
Enable(STATUSOLD);
//Disable(CANCEL);
StatusUpdate(ON, 100);
SetStatusWindow(0, "Setup is now adding healthcare information ...");
// copy webfiles
if (XCopyFile (SRCDIR ^ "\\Server\\*.*", TARGETDIR, COMP_UPDATE_DATE | INCLUDE_SUBDIR) < 0) then
fError=TRUE;
endif;
Disable(BACKGROUND);
SetAllFilesToNormal(TARGETDIR); // make sure any files copied from CDROM are not read-only
StatusUpdate(OFF, 100);
Disable(STATUSOLD);
return fError;
end;
Posted 06 December 2001 - 15:42
You might want to put all the blbrd files in a different dir under setup files pane and rename them after you know what you want to display. Sounds like IS is getting caught on your number of billboard files.
Posted 06 December 2001 - 16:10
"You might want to put all the blbrd files in a different dir under setup files pane"
The folder I use is "Setup" language Independent / operating system independent folder. I thought I had to use that folder. Is all of the setup files pane generically called SUPPORTDIR?
Posted 06 December 2001 - 17:11
Have you tried placing the minimum number of blbrd files and adding the extras if required...instead of removing?
