want to prepare my installer being executed silently. I want pass a serial number and installdir via CmdLine arg.
As I read so far, I have to capitalize the MSI property representing the license key (to be public), to overwrite it by passing it as argument.
I tried following cmd:
C:\Documents and Settings\MyMashine\Desktop\Installer>start /wait setup.exe
/S /v/qn /V LICENSEKEY=XXXX-XXXX-XXXX
but cmd prompt came back immediately and nothing has been installed.
Following cmd works:
C:\Documents and Settings\Administrator\Desktop\Installer>start /wait setup.exe
/S /v/qn
but uses default values (for sure, as nothing was passed)...
Do I have to prepare the MSI property to be able to be overwritten? Or is there a smarter way to pass data via cmd to the installer? Is it possible to overwrite installshield data like INSTALLDIR too?
Thanks in advande,
Thomas
Passing data vial cmdline
Th.M
, Jun 23 2008 13:23
Posted 24 June 2008 - 12:14
Are you using INstallShield 2009? As far as I know this is the first version that supports multiple /v arguments. For previous versions you must combine everything into one /v argument:
/v"/qn LICENSEKEY=XXXX-XXXX-XXXX"
You have to remove the blank between /v and LICENSEKEY.
I'm not sure but /v may be case sensitive, so use /v instead of /V.
If this still doesn't work generate a log file (www.msifaq.com/a/1022.htm) to see what's actually going on.
