Hi, any idea why if i click Tools, Check for Updates nothing happens? (InstallShield Developer 7.02 English).
Tools, Check for Updates does nothing.
Misec
, May 03 2002 12:48
Posted 07 May 2002 - 21:28
After installing 7.03 I had that same problem. Maybe this will also work for your 7.02. Here's what the InstallShield people told me to do:
Go to the Program Files\Common Files\InstallShield\Update Service directory. You should find the file agent.exe there (if it was someplace different in 7.02 just search for it). While in that directory run agent.exe with the command line of /REGSERVER. So the actual run command is agent.exe /REGSERVER
Hope this helps you.
Posted 28 May 2002 - 13:27
Thanks, unfortunatelly it didn't help. What helped was to check for updates from the other computer with installshield developer installed and it worked fine.
