I am new to InstallShield. My requirement is to migrate an existing InstallShield Professional Project (from Version 6.2) to InstallShield X.
I opened the project (.ipr) in InstallShield X and it migrated successfully.
When I was debugging the source, I encountered an error stating that one of the functions that was being called does not exist.
This function is defined in the _isUser.dll.
The problem that I am facing is that, even after I replace the _isUser.dll with the correct one that has the functions defined, when I start debugging and InstallShield does a build, it gets overwritten with another _isUser.dll which does not have the function. The dll that is built by InstallShield lies in <Project Folder>\_IsUser\1033.
I replaced the this _isUser.dll and also tried copying it to the "Setup Files\Compressed Files\0009-English\OS Independent" folder and also tried adding the _isUser.dll in the "Support Files\English" folder in the InstallShield Project.
All of this does not help. Is my approach correct? Or am I doing something fundamentally wrong? Please help.
Regards,
Sathish
Help needed with _isUser.dll
Sathish
, May 28 2004 06:41
