I have been trying to deploy Visio Viewer 2002 to machines where the users will not be administrators. The problem is that even though the installation is done everytime a user logs on some configuration is done. If the user is not a local admin on the machine the configuration will not be done correctly and subsequent doubleclicks on a .vsd file by that (non-admin) person does nothing.
The matter is further complicated by the fact that we use a hybrid system of MSIs and we import those into a .SPB file to be deployed by IBM's Tivoli Software Distribution. Anything that I need to do to fix this must be done within the MSI itself or a transform.
I have tried several things all with very dissapointing results. Instead of cluttering up the post I thought I would ask for suggestions and cross out the ones I've already tried.
Anything you guys can throw out would be helpful.
Thanks.
Visio Viewer 2002 MSI deploy to non-admin users
valgrom
, Jan 19 2005 23:43
Posted 20 January 2005 - 15:47
This article should help you find out why the installer launches unexpectedly:
http://www.msifaq.com/a/1037.htm
