Hello Everyone,
May I just used command lines to create *.EXE such as we used Install shield to create?
What should I do if I want to do that?
Should I create some files Install sheild script included then used dos command to call it?
Thanking you,
Sylvester.
DOS COMMAND CREATE EXE OF INSTALL_SHEILD AUTOMATIC
sly0000
, Apr 12 2007 17:05
Posted 13 April 2007 - 14:52
You can build your setup from the command line using InstallShield's command line build tool.
Posted 18 April 2007 - 09:30
Dear Stefan Krueger ,
thank you so much.
I used the keyword and find out a lot of informatio.
Thanking you,
Sylvester Liu.
thank you so much.
Thanking you,
Sylvester Liu.
