Hello there,
does anybody know how to suppress the MSI caching? I need to run the maintenance mode every time from the original msi and not from the cached.
Any suggestions?
Martin
Cached MSI
D-Ment
, Dec 19 2002 09:57
Posted 19 December 2002 - 14:30
this is a bit more indirect then you want but should achieve the desired results...
you could specify that the re-installation mode is set with a 'v' to run the re-install/maintenance from the source package and re-cache the local package...
for more info. check out the REINSTALLMODE property...
