Thanks for the help
inserting custom action
abc
, Jun 05 2001 18:22
Posted 05 June 2001 - 18:22
Is there a way to insert a custom action somewhere in between the "InstallWelcome" dialog sequence. I need to run a custom action after a certain dialog in that particular sequence but for some reason i am unable to do so.
Posted 06 June 2001 - 00:44
Instead of placing the dialog in the User Interface sequence, call the action off the next button of your dialog.
For example, if you wished the action to run after the Custom Setup dialog, go to the behaviour of the Custom Setup dialog, select the next button. At the end of the other things that take place, add the event "DoAction", the argument is the name of the custom action, set the condition to 1 if you want it to run every time.
