Hi All,
For all my components, i specify INSTALLDIR as destination, i set WindowsVolume as default installation directory. While running i changed the installation location to some other drive in "Choose Destination Location" panel. And it installs correctly in the location which i specified in the panel.
I tried to install somemore components, in modify option through Add/Remove programs, at that time it has to install in the location which i specified in the first installation, but it installing in the Default location (WindowsVolume drive).
What is the problem, can anyone help me to sort out it...
Thanks in Advance
Vishnu
Problem in Installation directory
vishnub
, Feb 01 2005 18:11
Posted 03 February 2005 - 08:51
The same issue is specified in this newsletter,
http://www.installsh...iPropUninst.asp
According to this newsletter, the INSTALLDIR value has to be stored in ARPINSTALLLOCATION property by a custom action. I have seen the entry of this action in Custom Action table, even after that it is not working.
I tried a workaround and its working fine, i stored the INSTALLDIR value in registry during first installation and retrieved the value during Maintenance mode.
Vishnu
Vishnu
