Hi there,
I have two questions:
1. I have a custom action in my application that I need to have run every time the MSI is run (except on a full uninstall). The custom action runs an executable "Installed with the application". This works fine except when I patch the application, the custom action does not run. The condition I am using on the action is: Not REMOVE~="ALL" OR PATCH
To my mind this should mean that the action should run when a patch is applied. What is wrong here?
2. I add an additional file to the applcation in one of my patches. The patch applies without problem, but the file remains on the system if I then perform a full uninstall. I can't make an entry in the RemoveFile table in the original MSI, because the file is not present, and I can't make one in the patch because the patch component never uninstalls. How can I set this file to remove on uninstall?
Matt
It patches...
HappyGod
, Feb 13 2004 09:27
Posted 13 February 2004 - 10:19
Sounds weired. A log file should give you more information about what's really going on.
BTW I don't understand why you put "OR PATCH". Not REMOVE~="ALL" shold also run in a patch.
