A bit puzzling..
all aspects of installshield allow you to create dynamic file links.
but for COM+ servers, this apparently does not work..
I wondering how I can streamline updates in COM+ packages??
now I need to create the COM+ package on mu develoment machine andrecreate the COM+ components in installshield.
I tried to link the components dynamically to the loation on the release folder. but apparently the CLSID's and typelibs don't get updated??
Am I going at this the wrong way? the resto of the installation, consisting of .NET componentes, com components websites, applicationpools, databases etc can all be built using dynamic file links.
many thanks for a reply..
installing COM+ packages
MrSensitive
, May 10 2007 14:46
Posted 21 May 2007 - 13:06
You should not use dynamic file linking for any components if you plan to update the setup at a later time with a minor or major upgrade. Installshield has a feature that allows you to sync the component GUID's between two releases, but in my experience this does not work reliably.
Your best bet, in my opinion, would be to revert to use statically linked components - preferably one component per file unless you have a lot of files to install.
