USING DIALOG INSTALLCHANGEFOLDER,
USER SHOULD SELECT ONLY WINDOWVOLUME FOLDER
ie C:\, or D:\,... etc.
After seleting that user will not be allowed to give sub folder.
The sub folder will be pushed internally when clicked ok.
The subfolder is the installdir foder. MY application should run under [windowsvolume]\XYZ\. Here xyz is installfolder.
For this I make visible =false for foldername text box (Tail Editpath).
Want to know how to internally manupuliate the folder name So that after selection of dive name user do not give folder name the folder name should be installfolder. So the path becomes DriveName:\installfolder.
thanks
sanjoy
sanjoygr
, Feb 28 2006 12:36
Posted 28 February 2006 - 16:26
You can use a "set a path" custom action to append your subfolder to the user's drive selection. Note that WindowsVolume is a system variable and shouldn't be changed.
Posted 20 March 2006 - 07:28
I have done following process but have some problem.
Created an Custom Action CAChangeInstallDir
Following attributes for CA.
1.VBScript Fie name: MyFxiedFolder.vbs
2.ReturnProcessing:Asynchronous (Waits for exist code)
3.In-script execution:Immediate Execution
4.Execution Scheduling:Execute Only Once
The CA is called from the dialog box InstalledChangeFolder ControlName: OK - Type - Push Button
Event Name - Argument - Condition
DoAction - CAChangeInstallDir - 1
SetTargetPath - [_BrowseProperty] - 1
EndDialog - Return - 1
Coding in MyFxiedFolder.vbs
Option Explicit
Dim MyFixFolder,InstallDefaultPath,InstallDefaultFolder,StrCmpFolder
Dim WshShell
Set WshShell = WScript.CreateObject("WScript.Shell")
MyFixFolder="THRTE_4.7.5\"
InstallDefaultPath =Session.Property("INSTALLDIR")
If len(InstallDefaultPath)>3 Then
InstallDefaultFolder=left(InstallDefaultPath,3)
StrCmpFolder = StrComp(MyFixFolder,InstallDefaultFolder)
If StrCmpFolder <> 0 Then
Session.Property("INSTALLDIR")=Right(InstallDefaultPath,3) & MyFixFolder
End If
Elseif len(InstallDefaultPath)=3 then
Session.Property("INSTALLDIR")=InstallDefaultPath & MyFixFolder
End if
WshShell.Quit
While application is installed on selecting the change folder option it canot process and goes to theInstallation complete dialog.
Please let me know here is the fault or what I am missing.
Sanjoygr@yahoo.co.in
Option Explicit
Dim WshShell
End If
End if
WshShell.Quit
Edited by sanjoygr, 21 March 2006 - 13:43.
