I followed the instructions in "Avoiding Maintenance Mode in IS6". It seems to work well, with one glaring exception. If I add new components, the file groups within that new component will not get installed during reinstallation (using "ComponetReInstall()"). They will only be installed during a fresh installation. The only work around I know is not to add new components, but to include the file groups within the original components. Is there a way to add new components during reinstallation.
Avoiding Maintenance Mode Problems
rajkulkarni
, Mar 14 2005 17:33
Posted 14 March 2005 - 19:24
Well ComponetReInstall() is designed to automatically choose the previously selected components as it's general purpose is to be used for the "Repair" option in a maintenance mode setup.
Now in your case, you either need to present the user with the proper set of dialogs to dictate the new component selections -or- call say ComponentSetupTypeSet() to re-apply the default component selections for the indicated setup type (e.g. Typical).
Posted 14 March 2005 - 19:45
I only use one setup type, "Typical". I call the function, ComponentSetupTypeSet(MEDIA, "Typical") in OnFirstUIBefore. Should this function be also called in the maintenance function just before I call "ComponentReinstall"?
Posted 14 March 2005 - 20:09
I just tried calling ComponentSetupTypeSet(MEDIA, "Typical") in the maintenance function, OnMaintUIBefore. It had no effect. The new components were still not being installed. Here is the code:
SetStatusWindow(0, "");
Enable(STATUSEX);
StatusUpdate(ON, 100);
if (CMDLINE % "UNINSTALL") then
ComponentRemoveAll();
else
ComponentSetupTypeSet(MEDIA, "Typical");
ComponentReinstall();
endif;
Enable(STATUSEX);
else
endif;
Posted 14 March 2005 - 22:02
Hmm, I thought that call would have auto. reapplied the default selections for the specified setup type.
Well there probably is a more elegant solution, but in that case, you'll just have to manually select the components accordingly by calling ComponentListItems to get a list of the current components, evaluate the status via ComponentIsItemSelected, and then adjust any via ComponentSelectItem.
I actually do something similar for my setups since I don't use Maintenance mode either.
Good luck then and hope it helps.
Posted 15 March 2005 - 18:17
Thanks, that worked. That article about avoiding maintenance mode should be modified. It can cause misunderstandings when adding new components.
