Hi all,
When I run setup.exe that was created from a basic installshield MSI project with more than one language, A msi file and a mst file got generated in temp folder, they are called 64dc42.msi and 64dc43.mst. These names are differnet each time I run the setup. Anyway, when I finish the installation only the msi file got deleted. When I see the verbose log I got the following at the very end of the file.
MSI © (10:28) [13:38:12:155]: Product: My Product -- Installation operation completed successfully.
MSI © (10:28) [13:38:12:155]: Attempting to delete file C:\DOCUME~1\testa\LOCALS~1\Temp\64dc43.mst
MSI © (10:28) [13:38:12:155]: Unable to delete the file. LastError = 32
MSI © (10:28) [13:38:12:171]: Grabbed execution mutex.
MSI © (10:28) [13:38:12:171]: Cleaning up uninstalled install packages, if any exist
MSI © (10:28) [13:38:12:171]: MainEngineThread is returning 0
=== Verbose logging stopped: 4/7/2005 13:38:12 ===
error 32 means that the handler is not released. Why is that happening?
Is there any suggestions on how to fix that??
THank you all
A mst file doesn't get deleted from %TEMP% folder
InstallDev
, Apr 07 2005 18:42
