I am experiencing a strange problem.
I want to install COM+ Application proxies on the target machine for which I generated Proxies using the “Export” feature provided in Component Services.
I then generated Wise Project files using the MSIs (as I am using Wise for Windows Installer 5.1)
As I noticed, it along with all the other necessary binaries, generated a .tmp file in which all the registration information is stored.
Now I have a custom action in which I use the InstallApplication method (in COM Admin catalog) to install them. (the MSI’s which gets generated during every build using the Wise project files I described above).
This method hangs the machine when I try to execute it.
There is something wrong with that .tmp file, but can’t figure out what exactly is going on.
During debugging I realized that InstallFinalize is the action that never gets executed.
When I can install the same MSI by double clicking on it.
Then y can’t I use InstallApplication??????
Any clue???
Regards,
Akshay Arora.
ND.
InstallApplication method hangs.
installer_wow
, Jul 12 2004 08:38
Posted 13 July 2004 - 02:07
I have never had the pleasure to work with COM+, so I cannot really help you. However, InstallFinalize is the end of the windows installer transaction that takes place in a setup's InstallExecute sequence. Windows Installer does not allow two concurrent InstallExecute sequences, so I suppose it may be your problem. The reason I think this may be the case is tha the MSI installs OK when you click on it.
