I am using InstallShield 10.5 and recently I ran into the following problem.
Even with setting ALLUSERS to 1, the program folders and shortcuts are created under %user%, not All Users. I have checked the log file which seems to be okay (i.e. ALLUSERS=1, AdminUser=1). Can anyone tell me what could have been the cause of the problem?
Thanks!
Per-Machine installation
lumnut
, Jan 05 2006 02:14
Posted 05 January 2006 - 11:33
Check the name of the folder that your shortcuts are being installed in ("Directory" column of the "Shortcut" table)... Can this folder be traced back (from child to parent) to a folder called "ProgramMenuFolder" in the "Directory" table? In other words, is the folder a child of "ProgramMenuFolder"?
Posted 09 January 2006 - 23:09
It turns out to be appsearch issue with active directory. http://forum.install...launchcondition
I have removed the appsearch condition and made into a custom action instead.
Thanks for your help.
