I try to present a html file as a Readme at the end of setup. I made a simple CA for this. When Internet Explorer opens, I get a message "Internet Explorer Compatibility Error" - "This is beeing run in compatibility mode and not all features are enabled", with an OK button. Otherwise, the page appears correctly. I have Internet Explorer 6. Any ideas?
Thx,
I.
Error in launching Internet Explorer
irinaca
, Nov 01 2002 07:59
Posted 01 November 2002 - 19:42
How is it you are launching IE?
Have you tried a custom action?
Try this...
set IE = CreateObject("internetexplorer.application")
IE.visible=true
IE.Navigate "http://www.yoursite.com"
set IE = Nothing
I have use this as an inline script and it works quite well. You can also do an ON ERROR RESUME NEXT at the start if you don't care about errors.
Try this...
IE.visible=true
set IE = Nothing
Posted 01 November 2002 - 22:42
Thank you for your answer, it seems to work, only...the html is installed with the application. I cannot figure out how to
navigate to [INSTALLDIR] in that script.
I appreciate your help.
Posted 03 September 2003 - 17:07
function MyFunc(szUrl)
object IE;
begin
set IE = CreateObject("internetexplorer.application");
if(!IsObject (IE)) then
MessageBox("Could not find Microsoft Internet Explorer on this PC!", SEVERE);
else
IE.visible = TRUE;
IE.Navigate(szUrl);
set IE = NOTHING;
endif;
end;
object IE;
begin
else
IE.visible = TRUE;
IE.Navigate(szUrl);
set IE = NOTHING;
endif;
end;
