The I have found the following for InstallShield 6, how is this done in the windows installer?
// FUNCTION: NTFS_Fix
// Called From: OnFirstUIAfter
// Purpose: Called only on Windows 2000 (though I don't see why it wouldn't work
//on Windows NT) to fix default NTFS permissions problem on Windows 2000.
//In this example, the target directory permissions are set to
//Full for Everyone.
//We use Windows 2000 (and Windows NT) built-in command
//cacls for adding the proper permissions. The command
//for adding User Modify (and thus Write) permissions for
//all files and subdirectories in the TARGETDIR (and the
//TARGETDIR itself) are:
//cacls TARGETDIR /T /E /G Users:C
//Full access rights for everyone would be:
//cacls TARGETDIR /T /E /G Everyone:F
//To get this to execute, we have to wrap all this up in an
//NT/Win2000 cmd entry, i.e.
//WINSYSDIR ^ cmd.exe /c <string above>
//IMPORTANT: Put TARGETDIR in quotes
//Note: We don't need to test for whether the
//directory is NTFS or not -- it runs without error
//on FAT directories (though it doesn't do anything)
//TBD: Test for FAT32 and see that it works there,
//too.
function NTFS_Fix()
STRING szCmd, szCmdArgs;
begin
// if(SYSINFO.WINNT.bWin2000) then // only on Windows 2000
szCmd = WINSYSDIR ^ "cmd.exe";
szCmdArgs = "/c cacls \"" + TARGETDIR + "\" /T /E /G Everyone:F";
LaunchAppAndWait(szCmd, szCmdArgs, WAIT);
// Note: Actually, I use a variation of the wonderful HideAppAndWait()
// code on InstallSite (<www.installsite.org>) instead of LaunchAppAndWait(),
// so I can check and see that the return code is 0. I use LaunchAppAndWait()
// here for wider compatibility.
// PS Thank you Stefan Krueger for all your help! We InstallShield
// developers are in your debt!!!
end;
