What's the best way to do this?
different EULA?
Kate
, Aug 13 2001 18:34
Posted 13 August 2001 - 18:34
I'm using ISWI 2.03. I'm building 2 setups from one project using release flags (it's partially localized - a few files only). Now, I've got to add another EULA so each setup needs to be built using the 2 different EULAs.
Posted 31 August 2001 - 20:56
We are using four EULAs in our installs--under two different schemas--for four separate regions.
In the current system: a dialogue before the License agreement with a radio control group for the user to select a region. The license agreement itself has 4 ScrollableText areas--they are hidden, and the appropriate one is revealed based upon the selection in previous dialogue.
We will be switching, presently, to having a drop-down menu selection--with selection & display on the same dialogue: Word of caution, the combo box control needs to have an height of ~100 [or it just won't work].
If either of these solutions works for you, I'll gladly provide more information.
Hope this is of use.
