Hi All!
I am facing issues with a QuickPatch project I have created. The build seems to be fine, I am just replacing two or three files from my original msi by choosing "Files to Patch", and specifying the file I would like to replace them with in the right hand pane.
However, once I run the exe for the QuickPatch, it halts with this error:
Error 2715: The specified file key [......] not found in the File Table.
I checked up the file key in the msi I am patching, and it turns out it's one of the files I've chosen as a "File to Patch". So why on earth is this happening? I've checked, and it's not a key file of its component either, so the file key definitely hasn't changed.
I would like to mention here that I am running only two of my original custom actions from the msi being patched in the QuickPatch project. Is that of any consequence?
I have also only chose "Files to Patch" and specified the corresponding files I would like to replace them with. I have no "inserted any new files".
Please help!
QuickPatch Issues
arshadtaylor
, Oct 08 2009 08:55
Posted 23 November 2009 - 14:30
So what I did is check all boxes for the following in the "Files to Patch" explorer for the files I want to replace:
"Check this box to have the patch delete this file from the setup."
And I added the new files manually.
Now I get a new error:
Error 2727: The directory entry '[2]' does not exist in the Directory table.
I'm totally lost here. Please help me!!
Edited by arshadtaylor, 23 November 2009 - 14:38.
