I have distributed a version 2.0 of my soft.
The setup has been developped with ISWI 1.52.
Now, I have new binary files and new custom actions to include.
The marketing departement has decided that this version will be a 2.0.1 one. I have to update the 2.0 version.
Applying a msp seems to work but in Add/Remove programs menu, the 2 softs appear end so there is a conflict: removing 2.0.1 make 2.0 not work.
Is there any solution to remove the key of previous version when updating?
thanks for help.
When updating, the soft appears twice in AddRemove Programs
jsp
, Apr 09 2001 13:53
9 replies to this topic
Posted 16 May 2001 - 22:42
It is populated. I have not changed the upgrade code. I have the VersionMax set to the previous version number, and the Attributes set to MaxInclusive+MinInclusive+LanguageExclusive+MigrateFeatures. I have the ActionProperty field set to 'DetectedProducts', which is a property that exists. I also have SecureCustomProperties set to 'DetectedProducts'. I am running ISWI 2.03.
Posted 17 May 2001 - 06:03
I think you want the language to be inclusive instead of exclusive (else it will find any languages except those specified, an empty means ALL langauges).
I suggest that you display the value of your ActionProperty (e.g. in a VB Script MsgBox) for debugging to see if it gets set. Remember that the property name must be all capital letters.
Posted 18 May 2001 - 14:34
I am not sure but I think DetectedProducts should be DETECTEDPRODUCTS. It does not make sense to add a private propery to SecureCustomProperties
Posted 18 May 2001 - 16:21
Hmm - I think I missed the point somewhere that properties need to be all uppercase to be public :). I'll try that and see if that works... Thanks
