Can I install my program on a local drive, and move my Ini- folder to a network drive?
I want the Ini folder to be saved where the user and project datas are saved..
My userdata can I move to networkdrive using xcopyfile, but this does not work for my folder with inifiles.
I've tried to clean cache with writeproofstring("","","","").
But there seems that Installscript XCopy has problem copying from and to network location.
Anyone accountede this problem? And hopefully solved it..
Ini files
olsen
, Nov 21 2006 16:38
Posted 23 November 2006 - 14:24
My problem was solved by calling cmd.exe and doing the xcopy through cmd.
Posted 24 November 2006 - 12:47
I find that operations like these are generally best done from the application EXE rather than the setup. Perhaps this is what you are already doing?
