I'm using ISD 7.02 and created two Standard Projects.
I tried to copy existing eventhandlers from one Projects to another. The code is compiled without errors, but it is not recognized as an event handler ín the new project and therefore will never receive any event.
Even if I cut and paste an formerly working eventhandler inside the same project, the handler doesn't work anymore. It seems to be necessary to select the event from the combobox and copy only the function body.
What makes a function an event handler. The naming convention seems not to be sufficient ??
By the way, I tried this with feature event handlers. The features in both projects had the same name.
Greetings
Achim
Inserting event handlers by copying
buckelfliege
, Apr 26 2002 07:54
