Here i created three versions of the setups (say build1,build2,build3).with different version of files( say f1.1, f1.2,f1.3)respectively.
I create follwing patches(i changed only package code,product versions only)
1)Create a patch between build1 and build2(say patch1-2 )
2) Create a patch between build1 ,build2 and build3(say patch1-2-3 ) and i gave GUID of patch1-2(created in step 1) in the patch creation wizard while creating patch 1-2-3.
Following steps i followed while applying the patch.
1) Install the build1 and applied the patch1-2 and patch1-2-3 .In both case it update the files successfully
2) Install the Build2 and apply the patch1-2-3
then i got error 1636.
Note : iam using ISD 7.01and stanadard project
pls help me out how to create single patch for multiple builds(with different versions)
regards
param
