I would like to add some new components to an existing installation by using update. problem is that the new components are being added only when the windows installer version is higher then 1.5.
is it not possible to add components when using a lower version? is the only solution is Uninstall/reinstall again?
how can I check the windows installer version of a machine from inside of another installation?.
does it means that users who has lower versions of windows installer would always have to uninstall/reinstall without being able to run a new installation and overwrite an existing one without uninstall?.
Thanks.
Add new components to an existing installation
TAL
, Apr 18 2002 13:33
Posted 19 April 2002 - 00:03
With older versions of Windows Installer, you could not add new components to existing features. You had to create an additional feature/subfeature, then add the components to that new feature. You could then use ADDLOCAL on the command line to install the new feature.
I'm guessing that this is your problem, because this limitation has been removed from MSI 2.0
