Hi ,
I am facing a problem as..
When i am trying to do over installation, FileInUse Dialog Pops up. But the list showed in the dialog is empty. if i close all the other application running then installation proceeding further. How to find out which files in use and which application need to close or to list in the dialog..
Any help in this regard is much appreciated.
I am using IS10.5 and project type is InstallscriptMSI
Thanks in advance.
Shekhar
FileinUse Dialog pops up with empty list
Shekhar
, Apr 19 2006 00:16
Posted 20 April 2006 - 18:23
Please anyone help me. I am facing this problem long time and not able to go ahead...
thanks
Shekhar........
thanks
Shekhar........
Posted 20 April 2006 - 23:46
I would open the task list and kill one process at a time until the dialog disappears (careful what processes you terminate).
That being said I think this dialog might be showing up because you are installing a file you shouldn't (perhaps a temp file, an IE file or something like that).
