I'm trying to do what should be a simple thing: install an executable with an advertised shortcut on the desktop. The shortcut needs to be created only if a certain property is set (the user needs to checks a checkbox during install).
I need the shortcut to be advertised because my application needs to be able to run either local or from source.
In order to achieve this I had to create two identical components, both containing the same executable, but one also containing the extra Desktop shortcut. The 2 components have mutually exclusive conditions, based on the property that controls the creation of desktop shortcuts.
There are 2 problems here though:
1. My installer greatly increased in size since my big executable now is stored twice in the MSI.
2. I keep getting ICE30 warnings during validation, and I know that it's not good practice to install the same file in the same location by two different components.
Can this conditional installation of advertised desktop shortcuts be achieved in a different way then?
Thanks!
Catalin
Conditional Advertised Desktop Shortcuts
Catalin_Negrila
, Feb 05 2007 19:57
Posted 06 February 2007 - 18:53
You could conditionally copy the shortcut from the start menu to the desktop.
