I'm including the ODBC 3.51 object in one of my IS 6.2 projects. Everything works fine, except on one system (WinNT4, SP6) on which the OLEAUT32.DLL is apparently "in use" when IS attempts to install the ODBC object (which includes OLEAUT32.DLL).
It appears that the ODBC object does not know how to handle "locked" files (such as OLEAUT32.DLL). Does anyone know some way of getting around this problem? (BTW, it was not possible to manually register that DLL using REGSVR32 - apparently, an "in use" file just cannot be registered!)
Wayne
