Even the simples of setups returns error 1628 when installing on NT4 all my setups are fine with win 2000 and all were fine until I upgraded to 7.01. Has anyone else come across this?
7.01 gives error 1628 on NT4
Simon
, Dec 12 2001 09:37
Posted 19 December 2001 - 16:22
Maybe it is caused by Windows Installer.
With IS Dev7.01 Windows Installer 2.0 is used instead of Windows Installer 1.2 .
Windows installer 2.0 requires NT 4.0 SP6. So when your NT version is older that will cause some problems.
Posted 19 December 2001 - 16:40
Thanks for the response, the problem’s fixed now, it was my development PC that was having problems. I installed Dev 7.0 and then Dev 7.01 on another PC and it was fine. I suspect it had something to do with manually upgrading to MSI 2 which made the Dev 7.01 upgrade not work correctly.
