I run am application from InstallScript (Developer 7) which creates a "dos" window with information. Normaly you can "pipe" this screen into a textfile with ">"-operator.
I used the following line:
LaunchAppAndWait ( "C:\\DMS32\\Source~1\\Hardlock\\hldinst" , "-info > c:\temp.txt" , WAIT );
I get the expected screen, but I can`t "pipe " it into the textfile.
If I use the windows command line outside Dev7 it works fine.
Where is the problem??
Thomas
