Does anyone know of a way to remove a Registry key using VBScript?
Or, is there an InstallScript function to do this?
Any help would be greatly appreciated.
Remove Registry Entry via VBScript?
Superfreak3
, May 21 2004 21:50
Posted 22 May 2004 - 04:27
You could take a look at this page (section delete key):
http://www.serverwat...cle.php/1476861
There also is a way to delete registry keys and values by calling regedit.exe from a reg file if this is more convenient for you and in Installscript it should certainly be possible.
Edited by Glytzhkof, 22 May 2004 - 04:28.
Posted 23 May 2004 - 23:41
Is there any link for reference on using Regedit.exe to delete a key with a reg file?
Posted 24 May 2004 - 10:41
You need to call regedit.exe in silent mode passing in a reg-file that contains the key/value you want to delete with minus in front. Should be something like this:
| regedit.exe /s filename.reg |
To delete a registry key:
REGEDIT4 [-HKEY_CURRENT_USER\Software\Company\App\ARegistryKey] |
Do delete a registry value:
REGEDIT4 [HKEY_CURRENT_USER\Software\Company\App\ARegistryKey] "Dir"=- |
Edited by Glytzhkof, 24 May 2004 - 10:59.
Posted 24 May 2004 - 18:11
Based on your info, I called Regedit.exe from a CA using a directory path (directory table). The arguement was Regedit.exe /s MyFile.reg. The reg file, which I simply installed with this process, contained the Registry key I wanted to delete.
It seems to be working perfectly.
I still don't know why Developer8 seems to be adding an InprocServer32 Key to the registry entries for an ActiveX component we are installing. This wasn't the case using ISWI 2.03.
Oh well, I'll take the workaround!
Posted 25 May 2004 - 04:35
OK, glad you found something that works. One word of warning: I haven't tested this registry scripts on Windows 95, might not work.
Finally, if you get an InprocServer32 key in the registry I'd say there is something wrong with the Active X component's self-registration code. Usually ActiveX containers use ATL to define the self-registration code in a file with extension *.rgs. You could have a look in this file to see if you see an InprocServer32 value.
Posted 25 May 2004 - 10:28
when using reg files, keep in mind that there has to be an empty line at the end of the file. otherwise the last line might not be written/deleted ...
Gruß / regards
Thomas
Thomas
Posted 25 May 2004 - 11:56
Thanks Perotin, I forgot that. And there is no end to the advice: remember to save the file as ANSI and not as Unicode (Windows 2000 and up often default to unicode), and make sure the first line reads:
"REGEDIT4"
and not
"Windows Registry Editor Version 5.00"
Otherwise the file is not readable on Win9X systems. Sorry for not mentioning this earlier.
"REGEDIT4"
and not
