I have been working through some problems setting installdir and various other directories through custom actions, and as I have not seen any concrete documentation on this issue, I thought I would post what I think is happening and see if anyone out there can confirm or deny.
1. If you set a property with the same name as a key in the directory table (e.g. from the command line or using a custom action), it becomes the default path for that directory while CostFinalize is run. This also becomes the base point for all subdirectories (as they are resolved after this point).
This makes sense because you set directories via the commandline as properties. I have seen this hinted in the microsoft documentation but the behaviour does not appear to be explicitly documented.
2. If you set a directory after CostFinalize is run (using custom action 35) this will change the directory, but not any subdirectories, I imagine because they have already been resolved during CostFinalize. Is this correct?
Richard
Custom Actions, Directories and Subdirectories
rmatheson
, Jan 17 2007 20:54
