I have a simple setup, and I'd like it to always prompt the user to uninstall a previous installation. I noticed that if I rebuild the setup with a new package code and then run it, I get a message from Windows Installer that says that a package is already installed, and I should remove it from Control Panel. However, if I install and then run the same (unmodified) setup, I get to the Maintenance dialog. What I want is to get the Windows Installer message in this case too.
The question is: is there any (simple) way to achieve this behavior?
TIA
Edited by dmaftei, 26 February 2004 - 02:19.
