Hello
I'm trying to create a Windows Service using Installshield 2010.
This was easy using the Component Wizard until I was told that the Service Name had to be configurable by the user.
I thought I would be able to prompt the user for the Service Name, set a Property and then use the Property in the Component Wizard, Service Name field. (same for the Display Name and Description).
Unfortunately the Wizard doesn't accept square brackets, so effectively I can't use my property.
Does anyone know how I can do this?
Thanks in advance
Creating Windows Services using Properties
Seany
, Apr 22 2010 12:06
Posted 22 April 2010 - 13:55
Hello Me
I think I can just directly edit the MSI database and put the properties in that way?
Posted 22 April 2010 - 14:55
Hi again
That seems to work, I've noticed that my Windows Service is not uninstalled when i uninstall my application (this happens whether I've used Properties or not to set it up)
Is that correct? or should it remove the Service on uninstall?
Posted 22 April 2010 - 15:40
I think you need to make sure to set the propertiy to the same value during uninstall (property values are not preserved automatically).
Posted 23 April 2010 - 16:58
Hi I think my problem was that I had not created a ControlService component to delete my Service on uninstall.
I'm just making the move from Installscript to MSI so I guess I'm going to be making quite a few of these daft errors.
Thanks for your help
