Erro 1603 on Windows Xp
colutti
, May 06 2003 20:18
10 replies to this topic
Posted 06 May 2003 - 20:18
Hi
I have some problems during the instalation of Windows Installer. I try to install, but it give me a message "Error 1603" only on Windows XP.
I know that is a problem ocurred when the windows don´t have the Service Pack 1 installed. It´s true ? Any ideas ?
Posted 07 May 2003 - 15:07
set your install to full vebose logging ( the l*v option ) and use the MS WiLogUtl utility to analyze the results.
Posted 07 May 2003 - 18:22
Hi
The analyze of log file returned it:
MSI (s) (94:FC): Cleaning up uninstalled install packages, if any exist
MSI (s) (94:FC): MainEngineThread is returning 1603
MSI © (94:50): Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI © (94:50): MainEngineThread is returning 1603
Posted 08 May 2003 - 08:59
There must be another error message somewhere above these lines
Posted 12 May 2003 - 05:23
Also, try checking the Windows XP event viewer for the error. This should provide you with some more information about the error.
Posted 12 May 2003 - 13:42
Hi
The problem is I install in other versions of windows. Only in some versions of Windows XP don´t install.
I have to make some configuration, but i don´t know what to do.
Rafael Colucci
P.S: My english is not very good ...
Rafael Colucci
Posted 12 May 2003 - 17:27
Other log:
=== Log parado: 07/05/2003 14:02:59 ===
MSI (s) (94:FC): Note: 1: 1708
MSI (s) (94:FC): Produto: Prolink MSDE 2000 -- A operação de instalação falhou.
=== Verbose logging stopped: 07/05/2003 14:03:00 ===
Posted 12 May 2003 - 18:06
I believe there will be even more errors listed in your log.
Posted 12 May 2003 - 20:09
No, I don´t think. If you want, I can send my log file to you.
Thank you very much.
Rafael Colucci
Rafael Colucci
Posted 14 May 2003 - 08:28
If that is the only error in the log file, then it looks like maybe the Windows Installer service is broken?
Also, you install package could be corrupted, and thus failing at the particular point in the installation.
Who created the msi package that you are using?
Posted 14 May 2003 - 20:40
I don´t know what I do to see if my Windows Installer service is broken.
I created the msi package in Install Shield Developer 8 using a Standard Project.
I think that is a problem ocurred only in Windows XP, because in other versions of windows the installation don´t give me any error messages.
Do I need install the service pack 1 on the Windows XP ?
thank´s
Rafael Colucci
thank´s
Rafael Colucci
