1) get user input with UI
2) run custom actions
3) install files
what i'm wondering is if it's possible to run a standard or custom action while in the middle of the UI flow. for example, if the data entered by the user into a UI dialog needs validation, then I'd like to run an action to validate the data before the next dialog is shown, so that if there's a problem with the data, the user is warned and returned to the same data-entry dialog.
is this possible? does this go against recommended practices?
we're currently using only ORCA and VB/VC++ for setup authoring.
thank you
CM
