I honestly don't rely on the debugger too much. Mainly use MessageBoxes and log statements to deduce the problem.
However, when I do end up having to debug, something I've always wondered is how to easily see the value of a constant--both the pre-defined ones (i.e. LESS_THAN) and user-defined ones.
If I simply add them to watch list as is it says "Error: symbol '<constant>' not found".
Let me know if you can and thanks in advance.
Debugging Constants
Taco Bell
, Sep 18 2002 17:53
Posted 19 September 2002 - 21:02
I'm sure you've thought of this extremely ugly way of solving that problem, but if it helps...
Define a regular variable and set its value to your constant.
ie. nValueOfLESS_THAN = LESS_THAN
Then watch nValueOfLESS_THAN in the debugger.
Yech, it hurt me to even type that response. Unfortunately, I usually employ the 'ol message box debugger since I have 2 other systems to test on, so I don't have much expertise in using the debugger.
Hope this helped and didn't lower everyone's opinion of me
Posted 19 September 2002 - 21:09
Yeah, I too have two other systems to test on, so that's also why I haven't used the debugger much.
Yeah, I nee dent do all that work. Nowadays, I just do a search in my code or the help to look up the the declaration, but would like to really see it at runtime.
