Cross-posted from the InstallShield forums...
Hi all,
I'm a novice with DevStudio 9 (although I've used previous versions of InstallShield before).
Can anyone tell me how I update a Progress Bar Control on a custom dialog? I'd like to update the progress as I'm checking various system parameters/configuration which may take some time.
I think I've looked in the help and searched these forums but I couldn't find anything (although it is the end of a long week!)
Thanks in advance,
Paul.
Updating a progress bar control
ptyrrell
, Apr 26 2004 15:13
Posted 26 April 2004 - 22:03
You can set the percent value using the SetStatusWindow function.
Posted 27 April 2004 - 07:45
Stefan,
Many thanks for your reply.
Unfortunately I didn't make it clear in my first post - I meant a Progress Bar control on a custom dialog (not a 'standard' one that SetStatusWindow seems to work with.
So what I have is a custom dialog that is displayed when the installer is checking system configuration. I would like to start the checking as soon as the dialog is visible (i.e. no extra 'input' is required from the user). As the checks happen I would like to update the progress bar value. Once the checks are complete I want to enable the 'Next' button so that the user can move to the next step.
So I suppose I really have 2 problems that I can't work out how to solve:
- how do I update a Progress Bar control on a custom dialog (what 'call' should I make)?
- how can I start the checking routine as soon as the dialog loads? I've tried it in DLG_INIT but this seems to run before the dialog is visible.
Paul.
Paul.
