How can I to copy an existing bitmap (#103, for example) into my dialog created inside the isres.dll?
The dialog created by copying an existing one from the isres\dialog folder in the resource pane in the Visual C++ 6.0 of this dll dsw. The source dialog encludes the bitmap, but the copied one doesn't it...
Modifying an Existing Dialog Box in _isres.dll
Yehuda
, Feb 06 2002 15:02
Posted 06 February 2002 - 19:03
I'm not entirely sure what your question is. Do you want to modify the standard bitmap (#103) for the SdWelcome() and SdFinishXXX() dialogs?
If you just need to modify existing dialogs, just open up _isres.dll as a "resource" in MSVC. Select "bitmaps". Using the menu items, copy and paste into your _isuser.dll project. Edit as appropriate. If you have already copied the dialog you want, the process is the same as that.
I actually had to copy the dialog properties to a new bitmap resource, and created the bitmap in a real bitmap editor. MSVC seems to have a bug where it will paste the image with reduced bit-depth, resulting in a badly dithered image.
