Custom Setup dialog size description incorrect
Posted 10 May 2012 - 19:49
Posted 11 May 2012 - 11:58
If you uncheck the box, the text should change to "This feature frees up 1 MB on your hard drive."
Posted 11 May 2012 - 17:41
Posted 19 February 2014 - 13:51
I am doing a major upgrade. I have a feaure A and 2 subfeature A1 and A2. The problem is when it reaches the Feature Description in custom dialog box. It displays "This feature frees up 1 MB on your hard drive". instead of "This feature requires 10KB on yoour Hard Drive".
1. What could be the reason for the same.
2. On What situation, does it display "This feature frees up 1 MB on your hard drive" and on what situations it displays "This feature requires 10KB on your Hard Drive".
Can anyone please explain me.
Posted 20 February 2014 - 10:29
For example: Feature A used to be 10 MB in the old version and is 9 MB in the new version.
If you install the new version on a clean system it will tell you that it requires 9 MB.
If you install the new version on a system that has the old version installed it will free 1 MB.
Posted 20 February 2014 - 21:10
There are some hints in documentation topics "File Costing" and "FileCost Action".
Posted 25 February 2014 - 11:36
IN basic MSI project i have a feature A. sub feature A1 and A2. In version 1.0 in feature desc its says 24MB size. When i do a fresh install of v1.1 ; it says A1 feature size is 34MB . But when i am doing a major upgarde : v1.1 feature A1 : "it says that his feature frees up 1 MB on your hard drive" .
I may not sure why its happening as feature size in v1.1 the size has increased.
Posted 26 February 2014 - 04:51
Can anyone please help me on same the reason for such a behaviour
Edited by tnand53, 26 February 2014 - 05:09.
